Remove BB sleeve/sh...
[Closed] Remove BB sleeve/shell
[#8192371]
Hi all, I got an FSA BB30 conversion sleeve/shell for my 2014 carbon synapse. Fitted it today and it wasn't until it was in that I realised my frame is 73mm and this shell is 68mm, so it's not long enough. I know I should have checked but I didn't and now I'm stuck - I got it in easy enough but I'm not sure the best way to get it out? The bearings were easy enough with the park tool but this shell has a bit more grip than they did!
Is there a special tool for this?
Thanks.
Posted : 04/12/2016 5:58 pm
They are a bit of a bugger to get hold of (and pricy).I've got one you could borrow...but it weighs a ton so the postage might be a bit scary.
Posted : 04/12/2016 6:11 pm
Ice cubes in the sleeve, hot water on the shell?
Edit: That looks like the tool for the bearings not the sleeve.
Posted : 04/12/2016 6:12 pm
That's the doggy.Mine is the right one (I've done plenty).
Posted : 04/12/2016 6:26 pm
Thanks guys, I presume that tool works by force, i.e. a hammer on one end?
Just seen this video on youtube that works (I think) on the same principle but with an old bottom bracket, or even a new one - suspect their cheaper than the tool..
Posted : 04/12/2016 7:36 pm
You'll need a headset press (swiftly withdraws loan offer 😐 )
Posted : 04/12/2016 8:40 pm
Can't believe he used such a small hammer. Amateur.
Posted : 04/12/2016 8:49 pm
Is this the sort of thing I should trust the lbs to do or should I be going to a Cannondale specialst?
Posted : 04/12/2016 9:26 pm
