Reducing travel on ...
[Closed] Reducing travel on Rock Shox forks?
[#3675911]
I've got some sektors (and hopefully picking up some Dual air revs at the weekend).
So I'll have plenty of the 10mm spacers to play with.
The question is, can I keep adding spcers to the sektors to reduce travel further, i.e. will the Sektors run Ok at ~110mm with 4 spacers in them as they conly come supplied with 2 to make them 130mm?
Posted : 14/02/2012 12:59 pm
Bump...............
Posted : 14/02/2012 2:00 pm
I would like to know this ad i have some 150mm revs that i would like to run at 120mm is this possible or is the max drop 130mm ?
Posted : 15/02/2012 7:16 am
It should be possible but you won't know until you try. Are they coils spring or air spring? the only issue I can think of is if a coils spring you end up with too much preload or for a air spring too soft to prevent bottoming out
Posted : 15/02/2012 10:59 am
Mine's solo air, the coil sprung models are all u-turn.
Posted : 15/02/2012 11:01 am
woirth trying then. YOu will be reducing the starting volume of the air chamber so you might get some odd effects - ramp up too quick if enough preload to stop it sagging excessively but worth a try
Posted : 15/02/2012 11:04 am
