Does anyone know if Rockshox rct3 dual position 160-130mm pikes be reduced to 150-120mm travel?
Did it to my 650b pike dual positions so yes...just need to swap the air shaft.
I think this is the one you want: http://www.gabelprofi.de/en/RockShox/Spare-Parts/Air-Shaft-PIKE-Dual-Position-Air-160mm-travel-26-150mm-travel-27-5-can-be-used-to-change-travel-to-160mm-on-26-150mm-on-27-5-A1.html?listtype=search&searchparam=pike%20150%20shaft
let me know if you fancy selling the 130-160mm one (assuming it is the 27.5 model)
Cheers guys, mine are 26" and it will be on potential new bike
this one looks like what you want then: http://www.gabelprofi.de/en/RockShox/Spare-Parts/Air-Shaft-PIKE-Dual-Position-Air-150mm-travel-26-can-be-used-to-change-travel-to-150mm-on-26-A1.html?listtype=search&searchparam=pike%20150%20shaft
Loco will probably be able to get them in for you or he can machine the shaft if not.
