Reducing travel on ...
[Closed] Reducing travel on DT forks?
[#4621647]
Anyone done the above? Got some 150mm I want to reduce to 130mm, is it possible?
Posted : 04/12/2012 1:37 pm
 juan
No.
Posted : 04/12/2012 1:40 pm
Take a look at the link below:
http://fotos.mtb-news.de/p/605190
It shows the ABS airspring (which DT forks from 2011 onwards use). If you can find a spacer that fits at the bottom of the 'stack' then I don't see any reason why it wouldn't work - it would move up the air piston rod by however long the spacer is, hence reducing the travel. But, the spacer needs to be a snug fit around the gold anodized rod and it also needs to be the same diameter as the existing bottom piece of the airspring stack.
Posted : 04/12/2012 3:17 pm
That pic appears to already have a spacer in it.
Posted : 04/12/2012 3:45 pm
