Reducing travel on ...
[Closed] Reducing travel on a Reverb... Possible?
[#9384790]
Think the GF won't need 125mm drop, plus Reverb collar and fat saddle in her new frame. Thinking all that is 20mm too much for her inside leg.
Is there a way of reducing the travel on a Reverb?
It's currently 125mm. 100mm drop would suffice.
Posted : 15/06/2017 10:19 pm
Not easily AFAIK.
[url= http://singletrackworld.com/forum/topic/can-a-100mm-reverb-stealth-be-changed-to-125mm-travel ]This guy[/url] might swap ?
Posted : 15/06/2017 10:23 pm
Maybe I missing something, but why not leave it as it, but don't use all the travel?
Posted : 15/06/2017 10:54 pm
^^ surely the idea is that the height is always correct for climbing, not up and then down a bit. No?
Posted : 15/06/2017 11:00 pm
Ride it for a couple of weeks and it'll sag 20mm when you sit on it 😉
Posted : 15/06/2017 11:02 pm
I think the op has the reverb inserted all the way and the seat is to high. Correct?
Posted : 15/06/2017 11:03 pm
Ghetto, but don't some people use a cable tie or similar to limit travel?
Not pretty but I suppose it does the job?
Posted : 15/06/2017 11:07 pm
Tie a piece of string/wire below the collar and up too the seat clamp, to stop it extending fully.
Posted : 15/06/2017 11:37 pm
Speak to yeti dog he has a post on here trying to go the other way . Assuming the same diameter .
Posted : 16/06/2017 12:07 am
