Reducing standover ...
[Closed] Reducing standover height on child's bike
[#10240959]
Any tips how to reduce standover height on a frog 52? My son is ready to move on from his cnoc 14 to gears.
I can remove some of the seat tube as ive had to do on all his bikes so far, but I'm looking for a seat post and child's seat with the least height above the end of the seat tube as the seat and post  it came with seem to be quite "tall"?
Anyone done similar?
If so where did you get the replacement <span style="font-size: 0.8rem;">seatpost and saddle from? </span>
Posted : 24/09/2018 1:01 pm
 Bez
That's quite radical 😮 Doesn't this suggest you're moving him onto larger bikes prematurely?
Posted : 24/09/2018 1:08 pm
I'd suggest that if it's too big for him, then he's not ready...
Posted : 24/09/2018 1:13 pm
If I can reduce the standover height, I'll assess it again.
Maybe you both are correct, but I'll decide that when i've "adjusted" it, if that is ok with you?
Now does anyone have any ideas about a low standover saddle and seatpost?
Posted : 24/09/2018 1:21 pm
Posted : 24/09/2018 1:24 pm
Which tyres have you got on 40-406 or 47-406?  The narrower will drop the bike, but only by a small amount.
Posted : 24/09/2018 1:33 pm
not specifically the standover but from experience the issue you might find is that the reach on the Frog 52 is really long for intended minimum height. i ended up putting a 40cm stem on my son's bike to bring the bars into a comfortable position.
Posted : 24/09/2018 2:11 pm
big hammer to the top tube? Will make it slacker and commensurately more awesome at slaying tech trails in the park.
Posted : 24/09/2018 2:16 pm
Let the tyres down 30psi..
Chop the seat post down so you can slam it. Decathlon do a 35mm stem for £13
https://www.decathlon.co.uk/oversize-bike-stem-35mm-id_8402831.html
and then fit a short kids saddle so theres more room in front of it.
https://www.decathlon.co.uk/100-junior-bike-saddle-id_8380621.html
other than that i'm not sure theres much else that can be done.
Posted : 24/09/2018 2:21 pm
 kevs
Pivotal type seatpost and saddle have low stack, loads of bmx’s have them to get the saddle super low
Posted : 24/09/2018 2:25 pm
Honestly, while there are options on FS bikes if the rider is confident enough (I used spacers on the forks and offset bushings on the shock to lower standover), on a rigid bike if they're struggling to straddle the crossbar, then the bike is too big for them right now and, especially if you intend to ride offroad, they'll only end up injuring themselves.
Regarding saddle height (which is a different thing) and reach, these can be adjusted according to terrain, skill and rider height - i.e. maxed for the road, relaxed for the trail - and kids taught to start and stop from the crossbar, but this assumes a frame that is small enough to allow them to do this.
I'm sure that you have a pretty good idea already as to whether you're pushing him up a bit early...
Posted : 24/09/2018 2:31 pm
Ads678 Great, thanks - these are the sort of ideas I wanted.
I've also found that hoy bonaly seat and post are one piece and look promising for what i want to try.
I'll get one or the decathalon one, stick it on and see how he gets on before i get my hacksaw out...
Posted : 24/09/2018 3:01 pm
have you considered a pivotal seat and post, they have next to no stack height.
BMX stuff
Posted : 24/09/2018 3:06 pm
Thanks for the pivotal seat tip! They look like just what I had in mind
Posted : 24/09/2018 3:41 pm
