Recommend me some r...
[Closed] Recommend me some rigid forks
[#7126477]
Current commuter bike is built from spares and has got some RS Sektor forks fitted which feel like the right length for the frame when wound down to 110mm. Prior to fitting these I had some rigid salsa forks fitted which were 420mm long and royally screwed the handling (and pedalling -seat angle was way too steep). I'd like to go back to rigids at some point as I don't actually need the boinginess and the extra weight / servicing together with difficulties fitting a decent mudguard is not ideal. So any recommendations for a decent set of forks that would keep the handling about the same? Ideally bolt through, or at least forward facing dropouts (like the salsa) as running discs. Using 26" wheels BTW.
Ta.
Posted : 12/06/2015 10:58 am
Kona Project 2 for a 29er? Not sure how long that would be mind, but should be longer than a 'suspension adjusted' 26er.
I recently bought a pair of these for my Kona PHD to replace the standard carbon alloy ones. They are lovely, triple butted for comfort.
Posted : 12/06/2015 12:11 pm
eXotic?
Very similar to the Pro XCR 445 I've got on my SS, which are great.
Posted : 12/06/2015 12:25 pm
470mm (29er) fork worked really well on the 26" wheel Inbred I had years ago.
Usual susopension fork was a 120mm Pace.
Something like [url= http://www.ebay.co.uk/itm/CHARGE-29ER-RIGID-MOUNTAIN-BIKE-BICYCLE-MTB-FORK-DISC-MOUNT-NEW-BLACK-FREE-P-P-/251846890068?pt=LH_DefaultDomain_3&var=550748913249&hash=item3aa33e9254 ]THIS[/url]...
Posted : 12/06/2015 12:30 pm
