Recommend me some n...
[Closed] Recommend me some new chainrings....
[#2475152]
Going to have to replace the chainrings on my bike soon as all starting to get a bit worn out. Using a xt770 crankset.
Should I stick to shimano rings or try middleburn, blackspire or someone else. I seem to wear out granny rings quite quickly --> chainsuck.
Posted : 16/02/2011 2:23 pm
Chainsuck sucks.
I've a brand-new set of SLX M660 chainrings (very similar to XT, what with the composite middle ring and all) that I took off in order to make the chainset single ring. Been meaning to eBay them for a while.
Retails for blah, blah, blah, £60+? (a quick googling tells me). If you fancy them, posted by SD, for £25 my email's in my profile. 🙂
Posted : 16/02/2011 2:35 pm
After years of using middleburn SS/HC, I'm giving up and going to buy a deore crankset, swap the rings, keep the BB as a spare and try and sell the crank arms (still cheaper than buying the ring individually).
As a m8 asked me when I gave him the option, are the Middleburn's (which are double or more the price of the deore's) twice as good?
I couldn't tell him they were.. he went for the deore's.
Edit: To extend the life of your rings, & stop the chainsuck for a while - get a file and take out the hook that starting to form on your rings. Just done this (again) to some Middleburn and XT rings that had been driving me crazy.
Posted : 16/02/2011 2:37 pm
deore steel rings all the way, unless you are one of those weight-obsessed people...
Posted : 16/02/2011 2:44 pm
Deore steel for granny/middle.
Something posh for outer.
Posted : 16/02/2011 3:12 pm
FSA do a sensibly priced outer. I find it amusing how much people pay for a few grams of stamped out alu!
Posted : 16/02/2011 4:11 pm
I've always been a fan of TA rings especially on dual setups. Good luck find them 🙂
Alt choice would be Middleburn hard coats.
Posted : 16/02/2011 4:14 pm
At the moment I'm running two rings, 26 and 38. The 38 is a middleburn, the 26 started off as a middleburn, and chainsucked from new whenever you changed down. After it had bedded in a bit, it chainsucked constantly. I rode a whole 3 day weekend in Wales on my big ring it was so annoying.
I changed to a deore steel 26, and it was instantly cured. Now the only time it chainsucks is when its covered in mud and I change down under load ie: my fault.
Steel for me. I bought a 22t from the local (Henry Burton) and when I got it home, noticed it was STX/RC. Still works a treat though.
Posted : 16/02/2011 4:45 pm
