Recommend me some c...
[Closed] Recommend me some cheap commuter lights
[#4755394]
I'm looking for some cheap (but good enough) commuter lights.
Anybody know of any online deals floating around or can you recommend some.
Will be used on lit streets so only need to be seen, not to see with if that makes sense.
Front and back required. Any help appreciated!
Posted : 15/01/2013 9:28 pm
I use the lunar ones. Cheap, bright, reliable
Posted : 15/01/2013 9:42 pm
Perfect. Thanks for the replies. Will give them a shot.
Posted : 15/01/2013 9:44 pm
these from on-one are significantly cheaper and almost as good
http://www.on-one.co.uk/i/q/LIPHBPDRL/phaart_bleep_dual_05_watt_led_rear_light
Posted : 15/01/2013 9:47 pm
Cheers. Just ordered some.
Posted : 15/01/2013 10:15 pm
Avoid those Smart Lunar lights, they are VERY cheap lights dressed up to look fancy. They have all the water proofing of an open packet of biscuits, they are a fine beam of purple very old LED technology and they munch through batteries, none of which points make them a good commuter light.
Although TBH without spending about £60 of a F&R set of light & motions or Moon comets, MOST cheap lights are just that, cheaply made, give up the ghost whenever they feel light it and weak/ dissapointing output.
Posted : 15/01/2013 11:03 pm
