Recommend me: silve...
[Closed] Recommend me: silver single ring specific cranks that'll take 38T ring
[#743750]
I like middleburn but singlespeed (no spider) will only take 32T, (it's for a Rohloff geared).
So far, it's down to White Ind Eno's
Any others?
Posted : 29/07/2009 10:10 am
I've got some Raceface Evolve DH with a 38T DMR ring & RF BB for sale from my Rohloff set up - email in profile.
Posted : 29/07/2009 10:17 am
I need 170 cranks, they look mahoosive, and a bit agricultural for my needs, but thanks all the same snaps.
It's to replace these:
Posted : 29/07/2009 10:22 am
Can't help with other suggestions, but there were some ENO cranks for sale in another thread - I can't find the thread right now, but the seller was LittleBoyLuke@aol.com.
Posted : 29/07/2009 10:41 am
Cheers finnegan, but they were 175
Posted : 29/07/2009 10:50 am
Campag Centaur ultra torque, stiff, light, completely serviceable BB (takes 10 mins to grease the bearings) and pretty sure you can find a 38t ring for them, but the compact comes with a 34t and something big.
Posted : 29/07/2009 10:52 am
Quite like that tinsy, any more purchase info, and does that mean I can use one of those new CK headsets (same as Shimano etc compatibilty)?
Posted : 29/07/2009 6:12 pm
 IA
Middleburn are making (make?) 38t unos for rolhoff use - give them a call?
Posted : 29/07/2009 6:14 pm
Intersting IA, I emailed Middleburn last week and White Ind, only the latter have responded. I'll try calling them before making a descision. ta
Posted : 29/07/2009 6:18 pm
Middleburn do a 38. I have used 34 and even 32 with my rohloff. 34/15 or 34/13. You would need to be superhuman to break it in my opinion and I don't really miss the absolute top end...like the campy idea though, a little bit different, but whats the chainline? roady chainline is usually somewhat narrower?
Posted : 29/07/2009 11:06 pm
I'll let you know how I get on calling Middleburn later - they've still no replied to last weeks email. I've got the gearing spot on for me 38*16.
Good point on the campy road rings - guess other rings may fit it?
Posted : 30/07/2009 10:24 am
A Shimano standard road crankset (Ultegra/105) comes with 39/52T rings if that'd be manageable?
Posted : 30/07/2009 10:48 am
I've just got these. That's a 44t ring.
Posted : 30/07/2009 11:39 am
Update:I called Middleburn and found them very helpful, they do indeed do a 38T ring for the Uno, trouble is the chainline on SS is much different to running a Roholff, it can be done but bottom bracket lenths would need to be changed to suit. The Rohloff sprocket is right on the edge of the hub, where as a SS is further in towards the hub. An RS7 arm with a 'Dual' spider is the way to go - apparently!
Posted : 30/07/2009 5:13 pm
