I need a 70mm stem and >680mm bars to go on a black Cotic Soul. Any suggestions ??
Anyone got pics of Sunline v1 bars on a black frame, any good ?
Cheers.
easton bar stem combo i run that setup with ea30's on my sanderson.
I use a Thomson 70mm and an Easton carbon monkeylite on my Soul.
More options than you could possibly shake a stick at!
You'll not go far wrong with most makes these days, but pick what's important to you from the following...
-Price
-Weight
-Strength
-Looks
-Rise
-Width
How much width do you want? 680ish mm is fairly standard these days, some bars go up to 800mm! How much rise do you want? I prefer less these days myself, just bought some Raceface Diabolus' with only 12mm of rise for one of my bikes... I used to run 40mm rise bars all the time, these days I go for almost flat.
Stem wise, at 70mm go for something a bit beefier, with a 4 bolt faceplate. Flexy stems and wide bars do not make for confidence in the corners personally!
Aye a stem is a stem is a stem. just go on looks price weight. Bars fairly similar. Bontrager RL lowrise bars are 690, should be able to find some cheap.
On my xc bike (07 trance) I've got a thomson 70mm and easton ea70. love the setup.
Go for something [url= http://www.chromagbikes.com/products-home/blog ]a bit different[/url].
