Going 1x10 on my cx bike but I'm stumped about what's compatible with what ratio so can someone please help me out?
Gonna go for a 38t sprocket with a 11-36 cassette though I might push to a 40t up front if it's too light. Can anyone help me out with a Shimano Shadow+ that will work with that?
Any short or med cage, shimano deore/slx/xt/xtr.
There isn't one that will work.
If you are using road shifters then no, there isn't one that'll work. A 9 speed MTB mech will shift correctly, but no-one does one with a clutch.
Zee at a push? Maybe not.
This might help...
http://en.wikibooks.org/wiki/Bicycles/Maintenance_and_Repair/Gear-changing_Dimensions
If it comes to it, you can look at modding the pull ratio with a speed hole:
http://bb.nsmb.com/showthread.php?t=153122
(for 9 spd shimano shifters, 17mm from the cable clamp towards the pivot does a fine job... if you look at the underside of the arm, there is a little flat bit in just the right spot)
Not running road shifters, cheers glasgowdan
