Recommend me a top ...
[Closed] Recommend me a top tube battery bag / solution
[#5744928]
The supplied strap doesn't seem secure enough to stop the battery pack from rattling, are there any pouches or battery bags out there that will fit a 6 cell battery pack?
It's too big a battery to go under the stem, and as long as I can securely get it on my top tube I'll be happy but that's proving a problem, I want it proper sturdy as In no movement at all so when riding at night I can not have to think about it and messing with it constantly
Posted : 03/12/2013 10:33 pm
Strap/tie it into a bottle cage?
Posted : 03/12/2013 10:38 pm
Sorry forgot say bottle cage not an option and kinked top tube too
Posted : 03/12/2013 10:39 pm
Listening attentively as need same. Old lumi bag is what we both need..
Posted : 03/12/2013 10:40 pm
Lumi bag?
I had a smaller pouch type one for my 4 cell only just fit in but tbh even that moved around on rocky descents :/
Just want it totally totally secure with no movement
Posted : 03/12/2013 10:42 pm
Would it work lengthwise under the bars, a'la mine?
If the straps are short you could just stitch on longer bits of Velcro
Posted : 03/12/2013 10:45 pm
I think it's to wide tbh mate it's quite a chunky battery
The battery bag worked ok on the glow worm when I didn't have the extension cable tucked in it, but as soon as I did it caused it to just wobble about then the extension cable fell out too lol
Having said that the r8 battery has a stretchy curled type wire but I can't find a bag that will fit it
Posted : 03/12/2013 10:48 pm
Thanks to rocketdog, just had a bespoke bag made up by Judy...
http://www.beerbabe.co.uk/
Judy upcycles bike stuff and is brilliant in putting together something that works and fits what you need...
Posted : 03/12/2013 10:53 pm
Get a small feed bag that attaches onto your top tube/stem, the type that triathletes use, something like the one below which i happen to use, i can fit 2 C&B Seen or 2 Solarstorm batteries inside it (both 4 cell), it will comfortably hold a 6 cell battery.
[img] ?w=430&h=430&a=7[/img]
Posted : 03/12/2013 10:56 pm
A 12 inch strip of removable QR velcro costing about a quid would definitely do it.
There are heavier, more complicated and more expensive solutions, however, good luck in your quest. 🙂
Posted : 03/12/2013 10:57 pm
Mmm, I see what you mean, it is a stocky chunky one, where as longer and slimmer would work.
Have you looked at Low-pro camera pouches?
Posted : 03/12/2013 11:06 pm
Somafunk something like that would be great but a little smaller? That's the sort of thing I'm after but smaller literally just big enough for the battery
Carlos yep it's quite chunky all round long and thin would be ideal for bars but this would stick out loads at the front and I still think it would move
Good shout on the Lowe pro bags somebody must do something somewhere all it needs is a couple of Velcro straps
Posted : 03/12/2013 11:08 pm
They come in a variety of sizes, if you hunt about crc/wiggle (other bike shops are available) and tri shops i'm sure you'll find something
Posted : 03/12/2013 11:09 pm
I'm currently using my tri bento box on the top tube of my commuter!
Posted : 03/12/2013 11:11 pm
have mine in an old saddlebag
works a treat
Posted : 03/12/2013 11:22 pm
well ive emailed trout and smudge, troutie hasnt got one big enough for the hope r8 battery still waiting to hear back from smudge
wouldnt mind strapping it to the TT as long as it stayed put, will have a look at maybe trying to stick a couple of straps on, one on the top and one on the bottom if it will fit
Posted : 04/12/2013 9:39 am
There are plenty of top tube bags available, surely one of those might work
There's a Deuter shown above, but Topeak and Alpkit do ones, as well as quite a few other manucaturers
I have the Topeak Tribag for my phone and basic essentials, I've been pleased with it so far
Posted : 04/12/2013 1:16 pm
Reusable cableties? Solve all manner of rattly problems.
Posted : 04/12/2013 1:19 pm
I will be using one of these when it arrives dual purpose and good vfm
https://www.alpkit.com/products/fuel-pod
Posted : 04/12/2013 1:20 pm
