Recommend me a SS c...
[Closed] Recommend me a SS chainring for HT2 cranks
[#358345]
Can anyone recommend a SS chainring for HT2 cranks as I'm struggling to find one that sits "true" without sitting pissed and creating tight spots.
Tim
(tried Blackspire and Goldtech so far)
Posted : 03/03/2009 4:56 pm
surley stainless steel lasts forever
Posted : 03/03/2009 4:59 pm
Oh.
I've got a Blackspire and it's fine.....
Posted : 03/03/2009 5:00 pm
I've got an on-one S/S one you could pop round and try if you want tim...
Posted : 03/03/2009 5:02 pm
Cheers Luke. I might just do that as the ones I've tried don't sit "tight" on the cranks and offer a bit of movement, therefore creating tight spots :o(
I'm mobile again so could drop the wheel truing stand around if you still want to play with it?
PP - maybe it was just the one I had
Saladogger - I'm sure it does but does it work with HT2 well?
Posted : 03/03/2009 5:14 pm
that would be great Tim - finally ordered the spokes just today, funnily enough...
let me know when suits you - I'm here most days (although the rest of this week is looking a bit fraught...)
evenings are mostly fine though if that fits in with your workign better.
Posted : 03/03/2009 5:20 pm
It'll be next week as Mon/Tues are my days off now.
I'll email when I know what's what.
Tim
Posted : 03/03/2009 5:21 pm
Tim, mine's a Blackspire downhill ring, if that makes any difference? I only bought it because it was cheap and it's been brilliant. Hardly any wear at all...
Posted : 03/03/2009 5:22 pm
ok - thanks.
Posted : 03/03/2009 5:23 pm
E13 guide ring?
Posted : 03/03/2009 5:37 pm
I have had the surley chainring on my ht11 chainset for about 4 years no problem what so ever
It works
iirc both del and tim41 use the same
Posted : 04/03/2009 8:55 am
Cool, I'll try lining my Goldtec up again and if not I'll splash some cash.
Posted : 04/03/2009 9:02 am
 Del
hey Andy, long time no see.
to the OP, i don't think it's unusual to have a bit of room for manoeuvre, so if you want to eliminate any 'egg-shapedness' you'll have to have the bolts just nipped, rotate the cranks, and then tap the ring. in other words when you find a tight spot, tap the front of the ring towards the back of the bike, rotate the crank a bit further, and see if it goes tight again, and repeat, until you have the thing sat evenly all the way around.
TBH i never bothered with mine ( surly ), accept the chain goes a little bit loose and tight, and just make sure when i tension the chain that it doesn't get too tight in the tight bit.
Posted : 04/03/2009 9:46 am
SJS cycles own brand ones or Surly
Posted : 04/03/2009 9:48 am
Surley stainless steel are really nice, run one on my P7 SS. You will find there will pretty much always be a slightly tighter section so just ensure that you tension the chain based on that point. With a proper SS chainring & rear cog you will have nice deep teeth so even if it goes a bit loose it won't come off.
Posted : 04/03/2009 9:54 am
e-thirteen guide ring for me.
Light, true and wear very well.
Posted : 04/03/2009 9:58 am
i run a Goldtec DH 9spd ring, had to chop a bit out to make it fit properly, works fine
Posted : 04/03/2009 12:19 pm
1/8th singlespeed specific Goldtech 34t for me on a HT11 XT crank. No problems at all (running a bash ring too).
Posted : 04/03/2009 12:36 pm
