Recommend me a shoc...
[Closed] Recommend me a shock pump
[#9689686]
The Fox shock pump I use currently has a dial that goes up to 300 with a tiny space between useful fork air pressures i.e. it's difficult to judge changes of 5psi between 55 - 60 etc. I'd like an easier to read version, either a digital display or possibly a pump designed for the lower pressures that forks use. So any recommendations?
Posted : 27/11/2017 12:21 pm
Not cheap but the Syncros SP 1.0 is good.
Posted : 27/11/2017 12:30 pm
Just work off the sag - pressure will change as temperatures vary but if you get your sag right then you don’t need an accurate pressure
Different shock pumps can also vary in reported pressures - even digital ones.
Tho just to add - I use a Topeak DXG one that was about £28 and it seems ok. Doesn’t have a lot of separation between the 10psi markings tho
Posted : 27/11/2017 2:08 pm
https://www.athleteshop.co.uk/rockshox-300-psi-suspenion-pump-digital?as=athlete&kwd_id=20051-AGI-45033135986-ASI-336177864683-ASC1KNU6EN&gclid=Cj0KCQiAjO_QBRC4ARIsAD2FsXMkUnF3OXZc-WtXS_0X3kxeOSOihYuShLrrVuqtBzMzs1TL16eVBs4aApZrEALw_wcB
I have the RFX version which is a bit longer so quicker from 0 psi but its basically the same shock pump. Yes it isn't cheap but it is good.
Posted : 27/11/2017 2:14 pm
You're right, but it's not always easy to get an accurate sag reading. What I'd like is to be able to set the pressure to what I think it should be and then accurately adjust depending on sag by doing minor changes in the pressure. On my current shock pump, it's hard to tell if you've added in 2psi, 5psi or even put less in etc! so it's a bit trial and error.
Thanks for the recommendations, so far cheapest one is currently winning...
Posted : 27/11/2017 2:34 pm
