Hi, have an old Kona Caldera, and looking to stick a rigid for on it.
Anyone have any recommendations? Looking for something relatively cheap, probably second hand.
P2's?
Avoid anythign jumpy - ythey'll weight more than the frame and break your wrists.
look at [url= http://www.carboncycles.cc/?s=0&t=2&c=92&p=832& ]http://www.carboncycles.cc/?s=0&t=2&c=92&p=832&[/url] if you don't want carbon - light (they do vbrake version too) and cheapish. Have a pair on my wifes bike and they've been fine.
Have you bought from Carbon Cycles?
Ok? Delivery quick? etc? 🙂
Thanks
me?
yep. took 2 or 3 days to deliver - they hold stock in the uk.
Thanks, I'm very tempted by one of their Carbon forks.
P2s anything else is a crime!
older P2s, the grey ones if v brake only
newer ones make sure they are the x3 butted only if you need disc
pop up on ebay reasonably often
Salsa cromoto forks... Lovely
I have a set of P2's for sale shortly if your interested?
If its a steel Caldera (did they make an alloy one further down the line?) then P2 all the way. Failing that, the shorter of the Cromotos but suspect a P2 (look on retrobike) will be cheaper.
