Recommend me a rear...
[Closed] Recommend me a rear light, please!
[#6429425]
In preparation for the darker evening rides (and hopefully getting back on my bike) I'm looking for a rear light with either with a sturdy mounting bracket (i.e. not plastic) or something that sits under the seat out of the way.
I keep breaking the brackets, I've broken 3 off this year already (and I've not ridden for a couple of months due to back problems). So, presuming I get back on my bike next month, I'd like something that'l at least see the year out.
Ta
Posted : 21/08/2014 9:58 am
How do you break the brackets? In all my years cycling I've never had one break...
Posted : 21/08/2014 9:59 am
knog blinder seems pretty good for me so far.
Posted : 21/08/2014 10:00 am
what causes you to break the brackets?
I find the Smart Lunar R2 is a brilliant everyday light, but its not using rechargeable batteries
I also find the L&M Vis180 to be perfect for more serious use and recharges using micro USB port.
Posted : 21/08/2014 10:02 am
Smart Lunar R2 FWIW. Very bright, batteries seem to last ages
http://www.charleysbikeaccessories.co.uk/products/smart-lunar-r2-rear-light-2x-1-2-watt?utm_source=googlepla&utm_medium=cpc
Well, I do fall off regularly!
Where I ride, there many instances where I have to carry the bike over gates and stuff, for some reason I seem to catch them. Even when I'm being careful.
Posted : 21/08/2014 10:07 am
That smart lunar looks a good bet, not a bad price too.
Posted : 21/08/2014 10:09 am
This
[url= http://www.3peakscycles.com/p/6472/Cateye-Volt-300-Lumen-USB-Rear-Light ]http://www.3peakscycles.com/p/6472/Cateye-Volt-300-Lumen-USB-Rear-Light[/url]
Posted : 21/08/2014 10:35 am
if you are taking them off road, then they are best kept off the bike IMO. if you are wearing a backpack then most have points where you can clip them to your backpack (tip. use a cable tie to secure it properly)
also can be secured to back of helmet, again using zip ties.
Posted : 21/08/2014 10:55 am
Smart Lunar is great on road but IMO far too bright off road unless you are riding solo without anyone behind you...
For off road (with some road sections) I use on of the [url= http://www.wiggle.co.uk/cateye-tl-sl110-loop-led-rear-light/ ]cateye ones[/url] under the seat, stapped round the saddle rails, which is bright enough on flash mode but wont screw anyone's night vision. Also allows reverb to operate as normal
Posted : 21/08/2014 11:01 am
iainc - too bright off road! - thats a new weirdo one... rear lights are there to be seen by... so strange you say too bright... unless you mean when you are using cheeky trails.
personally turn off rear lights off road... and find when I return to the road I have to wipe a good load of muck off them before use.. a mucky faint rear light is pretty pointless.. a mucky bright light makes a lot more sense.
Posted : 21/08/2014 11:16 am
+1 for the L&M Vis180
Posted : 21/08/2014 11:33 am
eh ? riding in a group we mostly use not very bright rear lights while off road - lets you keep track if it gets a bit strung out. If anyone has a bright light that messes up vision of those behind they are usually told so 🙂 . As for cheeky trails, well riding in west of Scotland there ain't any 🙂
Posted : 21/08/2014 11:42 am
+2 for L&M vid 180
Posted : 21/08/2014 11:46 am
+1 Smart Lunar R2, brighter than a very bright thing, which is the whole point. Batteries seem to last for ages, and the units about to start its 3rd Winter, as opposed to the one a year purchases I was making on those long thin Cateye jobbies, which seem to let weather in for fun.
Posted : 21/08/2014 11:51 am
I use one of these on my mountain and road bikes:
http://fibreflare.com/
The shorter one fits under the seat quite nicely, with the brackets looped through saddle rails and round the seat post. As they are quite flexible they're less prone to breakages.
Posted : 21/08/2014 12:02 pm
I was going to recommend the [url= http://shop.seesense.cc/products/see-sense-rear-light ]See.Sense [/url] but the price has rather risen since I got mine from Kickstarter
Posted : 21/08/2014 12:19 pm
These are great, and the rubber band type mount is easy to fit remove so you can leave the light in the mount.
http://www.evanscycles.com/products/moon/comet-30-rear-light-ec042056
Posted : 21/08/2014 12:42 pm
