Recommend me a rain...
[Closed] Recommend me a rainproof, windproof light weight jacket
[#677845]
As the title says I'm looking to buy a rainproof and windproof jacket what do you all recommend, without really going nuts and breaking the bank.
Gareth
Posted : 01/07/2009 11:45 pm
Montane featherlite, you can pick one up for around £30, it fits in a jersey pocket and is an adequate showerproof, windproof top.
Posted : 02/07/2009 12:06 am
Re Featherlite, as Saintly says it's showerproof, not waterproof. Not sure where rainproof fits in this scale.
Definitely recommended though.
Posted : 02/07/2009 12:15 am
Hi saintly, you back surfing again................
This is just a bit heavier than the featherlight but still stuffs down into it`s little scrotum sack.
Delivered in 2days 😆
http://www.awcycles.co.uk/brands/Montane/Velocity_DT_Jacket/12436/index.aspx
Posted : 02/07/2009 12:19 am
This one is good, looks smart in black & feels like you're naked...
http://www.chainreactioncycles.com/Models.aspx?ModelID=29853
well made too & UK made!
Posted : 02/07/2009 8:33 am
Hmmmmm... I have a Montane Featherlite, but am loathed to use it most of the time - except in emergencies when I get caught out by unexpected bad weather. For this use it appears to be just about perfect - as you can stuff it away in its scrotum sack and just forget about it 'till you really need it.... but I wouldn't want to use it as my primary rain jacket - it's just waaaaaay waaaaaay tooo thin and tearable. I'm sure it'd fall to bits pretty quick if I used it all the time. A single layer of flimsy pertex is not very waterproof, breathable or warm either*.
I use a Ground Effect 'Flashgordon', which is great for right now in wintery rainy Tasmania, but I think you're probably looking for a lightweight UK summer jacket, Hmmmm...? For this use the Flashgordon would be simply too heavy (and fairly bulky too).
Good luck with your quest!
*NB I am using the basic Montane Featherlite - not the CRC H20 version as highlighted by one poster - dunno what that one is like, could be ok I suppose?
Posted : 02/07/2009 8:57 am
the h20 is fractionally thicker than the featherlite
mrs antigee is very happy with her featherlite but i wouldn't go out in the rain in it myself, maybe ok for a light shower - the h20 is great for stuffing in a pocket and is fine for a couple of hours then i find the sleeves get soaked thru and i start getting cold - i bought a black one then regretted it as when it starts raining hard and on the road i feel a little invisible - if i lost mine i'd sure buy another but it has limitations - i wouldn't set off in the rain with it
Posted : 02/07/2009 9:38 am
 aP
[url= http://www.kalenji-running.com/EN/protect-1000-windcheater-58423808/ ]Decathlon £12.95[/url]
Posted : 02/07/2009 9:46 am
Montane featherlite is ok for a light shower but won't stop full on rain, the Velocity_DT does, having used the one I got from Awcycles I'd recommend it, the sleeves are really long too. Find somewhere to try one on before you order to get the right size
Posted : 02/07/2009 9:50 am
Yup Velocity has very long sleeves and a high neck, hence reason I bought it.I am 6ft, 14+st, broad shouldered so need xl on most clothing, sometimes meaning it can be baggy everywhere but still snug across shoulders.
As said above I also have the featherlite one but having used it on a very wet day can vouch for the fact it does not stop water getting through. Also gets a bit sweaty on warms showery days, best just getting wet!! But as a windproof on a cold day it did it
j
n bobs.
Posted : 02/07/2009 2:06 pm
Hmmm, I think you're right. The H20 is good but it's not for heavy prolonged downpours unless like me you're happy to dry off naturally afterwards.
I don't mind getting a little damp as long as I can stay warm & the H20 does that for me by keeping the wind off.
Guess the Velocity may be better if you're looking for a fully waterproof over extended periods.
Posted : 02/07/2009 4:46 pm
