Recommend me a port...
[Closed] Recommend me a portable pressure washer!
[#9504872]
Must be small footprint, work without an electricity connection, and not too high pressure!
Thanks!
Posted : 20/08/2017 8:51 pm
Any experience with this?
http://www.hozelock.com/our-products/spraying/pressure-sprayer-pro/
Posted : 20/08/2017 9:07 pm
https://www.nomadwasher.com
ticks every box
Posted : 20/08/2017 9:13 pm
Apologies for the slight highjack, but when you are using one of these washers, is it worth diluting a cleaner (like Muc off?) in the water?
Ta
Posted : 20/08/2017 9:17 pm
[url]
Bought one of these at the beginning of the summer to stick in the camper. Worked great on our Alps trip
Posted : 20/08/2017 9:18 pm
Apologies for the slight highjack, but when you are using one of the washers, is it worth diluting a cleaner (like Muc off?) in the water?
Ta
no. it ****s any internal seals
Posted : 20/08/2017 9:19 pm
the nomad site seems to be down
I ordered a hozelock manual sprayer, probably the saddest thing I've ordered
Posted : 20/08/2017 9:20 pm
The pump up by hand things? My one saved me from screaming at a tubeless tyre that wouldn't go on so they do have their uses
Posted : 20/08/2017 9:24 pm
Tracey - Member
How is the battery life? Been tempted. If it had an optional 12v cable it might be perfect!
Posted : 20/08/2017 10:17 pm
Been used quite a bit. Not had to recharge it yet.
Posted : 20/08/2017 10:19 pm
The mobi v17 is what you want
Fully portable well made and 89.99 at crc
The mobi site is down becasue they went bust a few years ago all because of returns .
This was a simple sealing issue that got sorted but was too late
Crc bought all the stock
It was so succesful they bought the name and now have it made exclusively for them
Although under licene aqua2go sell the same thing but green and sealey the same but in orange
Sealey having a bottle for fluid and the aqua2go has an extra useless brush
All around the same price
I also have the hydroshot for the motorhome and its awesome but seriusly loud which isnt a problem in some situations but its bloody annoyingly loud if you hosing stuff down after a night ride in a quiet neighbourhood and it does have a battery guage
The mobi is a lot less noisy
The mobi v15 is almost silent but is 12v only
Hozelock and other pump sprayers are useless unless you live in calafornia ,i live in calderfornia and one of those hust doesnt cut it.
Do not add anythig. Other than cold water,warm water swells the seals ,muc off etc .....just dont .
Posted : 20/08/2017 10:34 pm
Would avoid a Mobi washer if I were you.
When I can afford to get a new one, I would rather pay more money for a better item.
I have the v15 and it keeps blowing fuses, contacted CRC who couldn't give a toss.
Tried using a 10A fuse instead of the 8A ones that keep blowing. Fuses don't blow but the cigar lighter plug has melted, so that's obviously too high a rating.
So I spent 70 quid for the washer, plus a few quid on fuses and don't have a functioning washer.
If you can afford to buy one and have it last a year (they only have a years warranty according to CRC) then it's probably great. Otherwise I'd look elsewhere (and check the warranty is better than a year!).
Si
Posted : 20/08/2017 10:52 pm
 Rio
That Worx one is on special offer on Amazon at the moment. I got one earler this year - if you think of it as a sprayer rather than a pressure washer then it's great; just don't expect it to clean your patio.
Posted : 20/08/2017 11:39 pm
Blowing fuses,check the power cable it will have a split in it.basic easy repair for even a chimp
Posted : 22/08/2017 9:03 pm
Checked that found no damage, replaced cable anyway, same issue.
Not sure what you mean by the chimp comment?
Posted : 22/08/2017 10:02 pm
Karcher bringing out a bike specific
https://cyclingindustry.news/karcher-oc3-cleaner-joins-madison-product-portfolio/
I would avoid Mobi, snapped connections, battery packing up and various other problems with mine 🙁
Posted : 23/08/2017 7:33 am
The karcher is already available at Halfords
http://www.halfords.com/motoring/car-cleaning/pressure-washers-hoses/karcher-oc3-portable-cleaner
Posted : 23/08/2017 7:40 am
