Recommend me a new ...
[Closed] Recommend me a new bladder.......
[#2641127]
not for me specifically, but for the Camelbak Mule, as the original one is terminally done in.
Doesn't really need to be bigger than 2 litres, anything better quality/value than a replacement Camelbak one?
Posted : 07/04/2011 8:02 pm
I use these
Posted : 07/04/2011 8:28 pm
as above much better!
Posted : 07/04/2011 8:38 pm
Is the bite valve good on them? I need something to replace my leaky Dakine
Posted : 07/04/2011 8:40 pm
 rs
I use the source one too, very good, just watch you don't pull the valve off when you unscrew it to drink!
Posted : 07/04/2011 8:41 pm
Very pleased with the quality of the Hydrapak that came in my Dakine 🙂 Removable hose is useful for putting it in the fridge and saves you having to thread the hose through the bag straps each time.
Posted : 07/04/2011 8:43 pm
probably a stupid question but you don't have to twist that valve every time you want a drink do you?
Posted : 07/04/2011 8:55 pm
I've only done this once and that was because the pipe had frozen, but it went back together ok and no leaks. Also available is a magnetic clip to hold the hose onto the bags shoulder strap - great bit of kit
Posted : 07/04/2011 8:57 pm
:oops:twist open then close when you are sat in the cafe and this preventing embrassing puddles when you sit on the valve
Posted : 07/04/2011 9:02 pm
