Recommend me a Long...
[Closed] Recommend me a Long Sleeve Rodie top.....
[#5063217]
MTBer through & through, or so I thought.........
Planning on doing a fair bit of road cycling too, but all my kit is MTB stuff.
Managed to bag a pair of DHB 3 / 4 bibs off here the other night, so bottom half sorted 🙂
Also have a pair of MTB spd's & shoes that will do.
Just need a top, quite fancy a Specialized Eureka, but wondered if the STW massive had any other recommendations.....
Thanks in advance,
Alan.
Posted : 13/04/2013 5:53 pm
How much do you want to spend? Castelli make very good kit, probably the best road kit I've used.
Posted : 13/04/2013 6:02 pm
Castelli stuff is very good. As is Craft. I lIke my Rapha long sleeve top, but no doubt someone will tell you I'm an idiot in a bit
Given the changeable weather we have in this tropical paradise, I would suggest a short sleeve top, some arm warmers and a gilet.
Arm warmers are much of a muchness, 'roubaix' lycra is a bit warmer than plain lycra, and gilets are available in a load of different weights and styles, from thin little windstopper fronted things to full thickness front and rear.
Coupled with a few different weights of baselayer, that should see you through the year.
Posted : 13/04/2013 6:04 pm
Then you can start to collect stuff....
Posted : 13/04/2013 6:06 pm
Oh, budget - that is a good point! 😕
£40 - £50.
Posted : 13/04/2013 6:07 pm
That's a "habit" right there that is crikey... 😀
Posted : 13/04/2013 6:09 pm
I've been happy with my Altura tops - good value for money and don't look quite as ridiculous as I would in some team replica lycra.
Have a look at DHB on Wiggle
Posted : 13/04/2013 6:10 pm
I just bought one of [url= http://www.endura.co.uk/Product.aspx?dept_id=126&prod_id=584 ]these long sleeve tops from endura[/url]. They're pretty lightweight and have a windproof front so if it's warm but not warm enough for a short sleeved top I wear it with a SS base layer. If it's cold then I wear it over a thermal woolen top.
Hope that helps.
Posted : 13/04/2013 6:11 pm
Okay that's castelli and rapha out then.
Posted : 13/04/2013 6:14 pm
That's the contents of two drawers, I have another 3....
I've got a bit of an issue with bike gear!
Posted : 13/04/2013 6:16 pm
+1 for Endura FS-260
Windproof front, roubaix style fluffy bits elsewhere. I wear mine on it's own on warm days, or as a jacket over a base layer when it's really cold.
Posted : 13/04/2013 6:28 pm
if thats your budget I'd say you can't go wrong with dhb
Posted : 13/04/2013 6:34 pm
I said that was the budget...... could probably push it a little, do like the look of the FS-260.
Posted : 13/04/2013 6:48 pm
Have a squint in Decathlon. I got a couple of long-sleeved tops for touring last year and got the pair for £50.
Posted : 13/04/2013 7:53 pm
Pearl Izumi. Should find some reasonable sale items at the moment. Comes in a variety of cuts and weights.
Don't get too thick. The best thing you can buy after a long sleeved jersey is a gilet. Get the two together.
Posted : 13/04/2013 8:01 pm
