Recommend me a larg...
[Closed] Recommend me a large volume fast rolling tyre...
[#2831074]
I'm after something to replace the 2.35 and 2.5 Highrollers I use. I've looked at the 2.4 Racing Ralph but I hear they wear very quickly. The Crossmark and Larsen come up a bit too small for my liking. It's for a hardcore hardtail. The Maxxis advantage in a 2.4 may be an option but the tread looks maybe a little too much for fast rolling?
Any opinions? Cheers.
Posted : 08/06/2011 6:31 pm
2.4 snakeskin nobby nics
Mahoosive and plenty quick
Posted : 08/06/2011 6:53 pm
 nbt
Bontrager XDX 2.4 came on my Gary Fisher Roscoe and really like them, I moved the part worn tires to the tandem and got a tubeless set - sadly they didn't last long in tubeless mode, I went through both tyres in the same ride, but as I bought them off here I have no idea if they had any damage to begin with. Nonetheless with tubes in I find the great all round tyres
maxxis ardent 2.25 front and aspen 2.25 on the rear.fast as **** and plenty big enough
Posted : 08/06/2011 6:54 pm
 SOAP
MAXXIS advantage front crossmark rear both 2.25 (summer) aDvantage/aDvantage (winter)
Posted : 08/06/2011 7:03 pm
+1 for the Ardent & Aspen combo.
Posted : 08/06/2011 7:07 pm
Thanks, I've heard the Nobbly Nics are good. I'll look into them. Not cheap though are they!
I doubt I could get a 2.25 Crossmark on a Sun Single track (31mm wide). I'm after a high volume tyre for fairly hard riding. How wide does the Ardent come up compared to a Highroller of the same size?
Ta for the advice.
Posted : 08/06/2011 7:09 pm
sparkingchains - Member
[url= http://www.on-one.co.uk/i/q/TYSCNICEVOSS/schwalbe-nobby-nic-evo-snake-skin-folding-tyre ]Not exactly expensive either[/url]
Ardents are way bigger than a high roller
Posted : 08/06/2011 7:13 pm
Cheers Steve, unfortunately On-one have sold all the Snake Skin versions. Wonder how tough the side walls are of the non-snakeskins to be that low weight at a 2.4.
Posted : 08/06/2011 7:17 pm
High roller front with Larsen rear here, great combo!
Posted : 08/06/2011 7:20 pm
2.25 aredent aspen are wider than a 2.35 high roller and bigger volume to.the 2.25 nobbynick is a decent winter choice
Posted : 08/06/2011 7:26 pm
mine last 2.5 summers with a lot of use.
Posted : 08/06/2011 7:27 pm
Ardents have huge volume due to a very high profile. The sidewall on a 2,25 is taller than a 2.4 Nic but the width is fairly average/slightly on the burly side. Resoanbly fast with a good floaty feel thats soaks up the hits
Posted : 08/06/2011 7:31 pm
SC, plenty tough enough, I've ran mine in the peaks and Welsh forests with very little damage.
Posted : 08/06/2011 7:32 pm
No personal experience of Advantages but I've seen someone post that the 2.4's are quicker rolling than High Rollers.
Posted : 08/06/2011 7:39 pm
Not sure mine will last that long but I'm on my second summer and they'll certainly last this year.
Posted : 08/06/2011 7:42 pm
2.2 Rubber Queen
Posted : 08/06/2011 7:49 pm
+1 for 2.4 snakeskin nobby nics
Posted : 08/06/2011 8:18 pm
Cheers everyone, very helpful! Those with Racing Ralphs saying they last a couple of years/summers are you doing much riding on rock?
Posted : 08/06/2011 8:19 pm
it's STW, no riding gets done here noob
Posted : 08/06/2011 8:20 pm
Dave E - I'm worried the non snakeskins will be tough enough on rock/slate and prone to pinch flats?
Posted : 08/06/2011 8:21 pm
Cotswolds stuff mostly for me which is dirt and loose rubble for the most part. They've done trips to c-y-b, mtb marathon, dyfi and various 24s too.
Posted : 08/06/2011 8:23 pm
jontydewolfe -
I wouldn't spend so much time worrying about spending more on bike tyres than my car tyres if I wasn't going to use them!
Posted : 08/06/2011 8:24 pm
pfft
Posted : 08/06/2011 8:25 pm
Maxxis Ardent are very good I have the big 2.4s, light and nice on rock. The only not so good thing is soft deep mud.. I leave them on my Nomad Carbon had them since i got the bike last summer & I dont change tyres unless they wear out... Used in Alps last year and here...no problems...plenty tough , light and no punctures yet!!(I use tubes too)
Posted : 08/06/2011 8:26 pm
Anyone tried the Kenda Slant Six? http://www.kendausa.com/en/home/bicycle/mountain/slant-six.aspx
Posted : 08/06/2011 8:27 pm
 SOAP
I thought schwalbe's were PAP.... but then I dont ride like a Pro! 😯
Posted : 08/06/2011 8:30 pm
Small Block 8 2.35 maybe? About the same size as your 2.5 HR, as fast as knobblies come, and wear-wise they last forever. Wouldn't put them on the front again but they're fantastic on the back. Decent weight too.
Posted : 08/06/2011 10:00 pm
