I have no knowledge of these at all, mainly for roadie use so tiny/light etc.
Ive seen some x-lab speedchuck's for £12..?
some similar wiggle ones for £4
any views or recommendations would be good..
Genuine Innovations Microflate Nano. I found out the hard way that the press to activate ones don't work as well, if at all. The Nano is excellent and I have one in each of three tool pods.
cheers TiRed, I'll go and have a look at them, cheap canisters are available for them?
I'll second the nano, managed to get one dirt cheap through ebay.
heres another one http://www.ebay.co.uk/itm/Genuine-Innovations-Tyre-Inflator-Kit-C-w-Saddle-Bag-Tyre-Levers-Etc-/390935210383?pt=UK_SportsLeisure_Cycling_BikeLocks_SR&hash=item5b058de98f
or get on here http://www.tyreinflators.co.uk/index.php?act=viewProd&productId=1139&category=8
slightly different co2 connector
cheers muddy I'll check those links out later on.
Yes 16oz SCREW THREAD required. I bought 12ox by mistake, but they are cheap.
I'm guessing the link for the ebay item is from hudson cycles in Rossignton Doncaster from the user name and "new item"
carpet gives it away too
http://hudsoncycles.co.uk/bike_shop/index.php?route=common/home/
I personally prefer one with a 'tap' on it so you can feather how fast the CO2 is released, less chance of blowing the tyre off the rim.
I have an SKS AirGun and in true STW style I cant really fault it, used to have a tiny Weldtite 'press and go' jobbie and found it almost impossible to use with any degree of control.
I've got one which locks on with a lever, then has a trigger to operate, and another which is one of the simple press-to-inflate ones. I find the simple one much easier to use.
