Recommend me a Co2 ...
[Closed] Recommend me a Co2 inflator
[#5250341]
Using stans flow need a co2 inflator any recommendations
Posted : 15/06/2013 8:36 pm
surely somebody has used these and can recommend one
Posted : 15/06/2013 10:13 pm
I have a genuine innovations air chuck, that I've used once on the road bike. It seemed to work perfectly and is a whole lot easier than pumping
Can't comment on stans flow
Posted : 15/06/2013 10:20 pm
I've got an SKS Airchamp, which is very good but takes unthreaded cartridges (can be a pain to get).
Be aware that CO2 [url= http://messageboard.notubes.com/viewtopic.php?f=1&t=66 ]isn't recommended[/url] with Stan's sealant, at least not the initial inflation anyway.
Posted : 15/06/2013 10:23 pm
Don't use CO2 with tubeless sealant, it does something to the latex solution causing the latex to clump together into a solid ball.
Just get a good tack pump.
You can get N2O cartridges which might work if you're desperate from www.creamsupplies.co.uk which is the same company as www.tyreinflators.co.uk just for a different market.
Posted : 15/06/2013 10:25 pm
cheers guys many thanks
Posted : 15/06/2013 10:53 pm
Cheap one off ebay. Never let me down yet.
Posted : 15/06/2013 11:08 pm
Ha use laughing gas instead 🙂
Posted : 15/06/2013 11:20 pm
As an aside, I wonder why we use CO2 and not N2 cartridges.
That catering supplies place has [url= http://www.creamsupplies.co.uk/argon-cartridges-non-threaded-pack-of-10/prod_1196.html?category= ]argon cartridges[/url] if you really want something that won't react with sealant.
Posted : 16/06/2013 9:31 am
And whatever you do, don't think about filling a balloon with the N2O and taking in the contents to your lungs, repeatedly 😉
It's nearly as much fun as riding your bike! 😀
Posted : 16/06/2013 9:40 am
i use the decathlon one. It's good, I got replacement cartidges from tyreinflators.co.uk in the larger 16g size.
I use it most often for getting the tyre seated on the rim, then you let it down and reinflate with a track pump easy as you like
