Recommend me a chai...
[Closed] Recommend me a chain guide
[#5833158]
Going 1x9 on my Nomad and want a iscg 05 chain guide for it.
Looked at MRP G3 and E13 LG1 but a lot of the reviews mention parts cracking while just riding along.
Is there one out there that wont fall to bits on me?
Thanks
Posted : 07/01/2014 5:34 pm
Can't fault my old style gamut p20. It has the lower roller. The newer one has a static lower roller, can't see much to go wrog with it. Never liked the look of e13s. Too much going on
Posted : 07/01/2014 6:01 pm
Both LG1 and NRP suffer from solvent-based lubes weakening the plastic - stick to solvent-free lubes and you'll have no hassles, they recommend lubes on their sites.
Own both, plastic parts of the LG1 are probably more solid.
Posted : 07/01/2014 6:07 pm
Straitline Silent Guide - No moving parts and nice solid machined bash guard.
Not cheap mind but you can pick up a second hand one for under 50 notes.
Mine has been faultless once I got the initial setup sorted and was happy to pay a bit more for something that will last, work and be maintenance free.
Posted : 07/01/2014 6:08 pm
there must be some good deals on s/hand chain guides now that narrow/wide rings have basically destroyed the market for them, on single ring setups at least.
Posted : 07/01/2014 6:15 pm
Bear in mind, due to the stupid lower VPP link on the Nomad, most chain guides won't actually fit properly, as they foul the pivot/chainstay.
The only one I could find that fitted mine was the Straitline Silentguide.
Posted : 07/01/2014 6:54 pm
Cheers for the replies guys, thanks for the heads up hob nob not heard of that problem.
Posted : 07/01/2014 11:55 pm
Save money on a chainguide and put it towards a 1x10 setup with clutch mech and thick/thin chainring.
Posted : 07/01/2014 11:58 pm
Can I mount a chainguide to my bike?
Yes, this bike has been designed with ISCG-05 chainguide mounting tabs. We have had great luck with the E13 LG1 Tr, MRP Lopes guide or Mini G3. For dual ring guides, try the E13 TRS+Dual or MRP 2x guides. These should fit with minimal or no modification.
From Santa Cruz FAQ - this is for the current Alu frame so just check.
Posted : 08/01/2014 12:00 am
Straitline silent guide, faultless & no moving parts so nothing to go wrong
Posted : 08/01/2014 12:01 am
