I have just discovered that my rear hub sounds like there is an internal squeal in the inside of the hub. I can't find a tech manual anywhere on the net as to how to rebuild these. Anyone help me out ??
Sean
[url= http://www.singletrackworld.com/forum/topic/on-one-hub-service ]see here[/url] 8)
Thanks Tim, unfortunately though Brants link doesn't work.....anyone got the paperwork they could scan and send me ? 😉
nbt's instructions are right. (There are no circlips.)
19mm socket to drift the bearings back in.
I have the guide downloaded. There's a grub screw holding the cap on the driveside apparently, but the rest is simple. If you can find instructions for the DMR revolver, I believe they're very similar.
