I have a mavic Kysrium front wheel I want to convert to a rear. How would I do that? Cheers. Ash
You would buy a rear hub and the correct spokes to match your rim. Then throw away thd rest of a front wheel.
its unlikely you'll manage with so few spokes.
Extremely unlikely to be cost effective on a factory wheel.
can it even be done at all?
there arent many spokes on the front ones i just googled.
As above, the chances of finding an 18 hole hub is v slim and may not be strong enough (unless you were v light)
I suppose you could get a 36 hole hub and just use every other hole haha*
*not sure if this is a good idea!!
Shermer i am going to let you think about that....
Edit: no i'm not i read ya wrong!
Hadnt even thought about spoke holes. Dammit. Could of got two fronts cheap, hence the question.
Never mind
