Rebas. How do you ...
[Closed] Rebas. How do you set up yours?
[#3862945]
Just out of interest.
Me - 13.5 stone, no jumps or big drops.
Positive chamber - just over 120psi.
Negative chamber - just under 120psi.
Rebound - 1 to 1.5 turns from minimum (fast).
Compression - Dunno, it's a screw under the lockout cap and I've never bothered adjusting it, feels fine as it is.
Floodgate (lockout blow-off type thingy) 1 turn from max.
How about you?
Posted : 12/04/2012 10:43 am
I'm 70 kg and mostly do XC. +120, -100 with red nob in the middle. I like a firm ride with only 80mm travel on my 29er and use the crown lock on climbs.
Posted : 12/04/2012 10:49 am
 GW
Mine are on a DJ bike I use as an allrounder so lots of jumping, am about 14st and use 155 pos, slightly less neg. Quickish rebound, FG off.
They use the full 100mm but never bottom harshly
Posted : 12/04/2012 10:58 am
Just under 12 stone & put about 115psi in both positive & negative chambers & have rebound set half way.
Played around with a few psi less, but I was using up 100 of the 120mm travel just cornering, so these pressures seem to prop it up much better.
Posted : 13/04/2012 10:25 pm
