reba travel adjust
[Closed] reba travel adjust
[#3930271]
I have 2010 dual air reba SL 100mm forks.
Does any know if this fork can have a spacer added/removed to make it 120mm ??
Posted : 01/05/2012 9:19 am
Some of them can. The only way to find out is open them up. Let all the ait out both the pos and neg chambers and unscrew the top of the pos chamber (again make sure all the air is out both the pos and neg ends) then slowly push the forks down until you can see the air cartdridge chamber. The black spacer will be near the top if you have one. If you have one and you remove it you will need to play arround with different air pressures to set them up again.
I did this to my 2008 rebas and got 115mm out of them. Perfect for me.
Posted : 01/05/2012 11:06 pm
