Is this fork likely to have adjustable travel or not?
SBC site specs it at 80mm, RS site states Reba SLs are 80-100-120
TIA
Adding/removing internal spacers generally changes the travel on these.
I bought a 26er stumpy that came with Fox Floats at 80mm and I changed to 100mm.
Quite an easy job
Thought so but wondered if these might be an OEM fork that does not adjust...I suppose that might not save them any tho...
Ah apparently they will go to 100mm.
there is a plastic spacer in each leg, i cant remeber whether you add them or take them out to increase travel, 80-100mm travel, if you look on mtbr forum there is a conversion using the u turn damper and coil which then lets you go all the way out to 115 down to 80 or 85mm from what i read
