Reba RL 100 to 120 ...
[Closed] Reba RL 100 to 120 increase
[#8383509]
I have a set of Reba RL forks 27.5 purchased last year from Merlin cycles.
They came with a service kit and shock pump so I believe they are retail forks.
So how do I increase the travel from 100 to 120, do I need to buy a new spacer/spring?
Posted : 04/03/2017 9:45 pm
If they are solo air you'll need a new air spring. I looked at reducing travel and unlike dual air where you can just pop a spacer on I needed to buy a new spring..they are about £30 on ebay. Not sure about increasing travel from the stock length though...would you need a new damper too?.
Posted : 04/03/2017 10:17 pm
You will just need to change the air shaft for a 120mm one. I did it to the Reba's on my 2015 Anthem & it's pretty straight forward. (When you watch someone do it on you tube first) 😉
Posted : 04/03/2017 11:06 pm
Cheers.
I'll have a look on yt.
Posted : 05/03/2017 10:50 am
