Reba Race 2008 fork...
[Closed] Reba Race 2008 forks - how to remove floodgate dial?
[#9352908]
The 2008 manual makes reference to the compression adjuster know being held in place with an external snap ring. However, my compression adjuster is held in place by a floodgate dial with a small hole in the side, at the base of which is a very shallow hexagonal recess (too shallow for an allen key to engage with).
Anyone got any suggestions as to how I could remove the floodgate and compression dials? I haven't tried servicing these 2nd-hand forks before - anyone know if I'm missing anything? Could something (e.g. a grub screw) have sheared off? Keen to give the dampener a service.
Cheers,
Will
Posted : 29/05/2017 12:42 pm
see that allen key bolt - undo it and take the cap off that way
iirc there is possibly a circlip underneath holding on the blue compression knob
Wait ofr other advice if it is a remote version as never serviced those
Posted : 29/05/2017 12:44 pm
Use a decent quality allen key, and dont use a ball end one.
Posted : 29/05/2017 1:30 pm
Grub screw looks fine you just need a decent Allen key of the right size by looks of it. It's fairly straightforwad to strip those down, just follow the tech manual on the sram site carefully.
Posted : 29/05/2017 2:09 pm
There's less than 0.5 mm for the allen key (which I thought was a good one) to catch on and it ain't catching!
nickdavies: you mention a grub screw yet I can see threads but no screw in the hole?
Posted : 29/05/2017 4:50 pm
Are you sure you have the right Allen key, i.e. 1.5mm?
Posted : 29/05/2017 7:07 pm
The picture isn't that clear but the hex in that grub screw looks worn out to me.
Posted : 29/05/2017 7:14 pm
looks worn to me [ having just zoomed in] trying tapping an oversize torx key into it to get purchase as we are into the territory of bigger hammer/ drill it out
Posted : 29/05/2017 7:31 pm
Not blocked with mud is it, tried cleaning out with pick/safety pin etc?
Posted : 29/05/2017 9:10 pm
Obviously it's a picture but it looks like there is a grub screw in there to me? 1.5mm IIRC on those. They do drop in quite deep, doesn't look much different to one of mine. They are pretty easy to get ham fisted though and round, if a decent Allen key won't bite and a Torx doesn't work I've used a watchmakers screwdriver before, gently tap it in and turn it in a fraction, counter intuitive but I find a little tweak tighter can break the bond.
Posted : 29/05/2017 11:06 pm
