Reba pressures - wh...
[Closed] Reba pressures - what are you running?
[#301828]
100mm travel
Pos and neg
Posted : 13/02/2009 11:07 am
130psi +ve and -ve at 115mm - I'm 16 stone
Posted : 13/02/2009 11:15 am
115m of travel, 14 stone 110psi in both +ve and -ve.
Posted : 13/02/2009 11:19 am
100mm 29ers and am 14st with 110 in both iirc
Posted : 13/02/2009 1:13 pm
100mm travel
80 positive, 90 negative
I'm 10.5 stone - extra negative for small bump responsiveness
Tim
Posted : 13/02/2009 2:05 pm
80+, 70-, 11st
Posted : 13/02/2009 2:08 pm
80psi in both, 11st. When they're new you might benefit from running more in the neg chamber and lower pressures overall as the seals take forever and a day to bed in.....but last a reassuringly long time!
Posted : 13/02/2009 2:18 pm
It depends on FAR too many variables to just ask what other people are running:
What bike, how much weight on the front, type of fork (U-turn or Dual Air, the chambers are slightly different)..... etc
Just trotting out air pressure settings and bodyweights means very little
The only way is to measure and set the sag properly yourself. I'd go for 20-25mm on a 100mm fork, but then you might like a bit more or less then that.
Posted : 13/02/2009 2:33 pm
Reba SL 100mm's. 125 +ve/-ve both sides and I'm 14st, have been round Llandegla at 100psi both sides and only just bottomed them out.
Posted : 13/02/2009 8:23 pm
I had Team rebas on a medium superlight 08s i ran them 110pos-neg90.Not a great fork not bad either.
Posted : 13/02/2009 8:45 pm
Set the +ve based on sag (25-30%) and then put the -ve 10 more than the +ve.
Posted : 13/02/2009 8:49 pm
