Reba motion control...
[Closed] Reba motion control oil weight?
[#1155903]
Heard I needed to get 15wt so I bought that. Watched the video carefully and it said the damper needs 5wt?
Posted : 24/12/2009 4:00 pm
yes, the huuuuuge rockshox service manual says you want 5wt just for the motion control (upper right leg) bit. 15wt for everywhere else. Silkolene motorbike 5wt fork oil is a good, affordable and easily get-hold-of-able alternative. as a bonus you can dunk your nipples in it when you build wheels. 😀
Posted : 24/12/2009 5:29 pm
I wouldnt get too worried over the weight of the oil. Ive used 5, 10 and 15 in my forks before. Never noticed the difference out on the trail.
Posted : 24/12/2009 5:44 pm
in the damper you will especially in cold weather
Posted : 24/12/2009 5:45 pm
5w in the damper, 15w for lubrication in the lower legs and air cartridge. You'll get away with 5w for lubrication, and possibly 15w for damping for a while, but you'll need to back off your rebound as the thicker oil will slow it down
Posted : 24/12/2009 5:48 pm
Thanks, got some automatic transmission fluid that I bought when I was poorer. They said it was 5wt, but god knows what it is. I just wanna get rid if it, so might give it a try. It smells the same as the stuff that came out of the damper at least. Never seen the manual, bought the forks from here.
Posted : 24/12/2009 6:31 pm
links to service guides for 07 08 and 09 forks here: [url= http://www.sram.com/en/service/rockshox/tech_manuals.php ]http://www.sram.com/en/service/rockshox/tech_manuals.php[/url]
merry servicing! 🙂
Posted : 24/12/2009 8:13 pm
Any oil will work in the damper, its just the thickness that matters.
Posted : 24/12/2009 8:14 pm
