hi
I just bought some RockShox XX Reba Dual Air 120 Suspension Fork 2010 which have a little notch on the arch for the disc hose routing. What do i need to get to ensure the hose is routed nicely rather than just using a cable tie which starts to scratch the fork??
it can be seen.... just ...in this image
easygroove - Member
hi
I just bought some RockShox XX Reba Dual Air 120 Suspension Fork 2010 which have a little notch on the arch for the disc hose routing. What do i need to get to ensure the hose is routed nicely rather than [b]just[/b] [b]us(e)[/b]ing [b]a cable tie[/b] which starts to scratch the fork?
I seem to remember my rockshox coming with a little plastic guide block and a cable tie for this
halfords thin rolls of velcro cut to size works lovely, 'muffy' side down obv. only a fiver too
Older forks had the plastic guide/self adhesive pad/zip tie that TJ's mentioned, latest ones just use a zip tie.Wrap a strip of tape underneath if you're bothered by it.
cable tie. it won't move.
