Reba against revala...
[Closed] Reba against revalation
[#6208802]
I was wondering what the diferance is apart from travel?
Posted : 21/05/2014 10:13 pm
 LoCo
Rev stiffer and has better damping, RCT3 compression damper on models since 2012.
I have run revs on my shorter travel bikes for the last 3 years reduced down to up to 100mm as I'm quite tall and 13.5 stone so wanted something a touch stiffer.
Posted : 21/05/2014 10:22 pm
LoCo,
Is that a mod that you can do reasonably easily / cheaply? Could you supply a set of 29" Revs pre-modded to 120mm for instance?
Posted : 22/05/2014 8:58 am
 LoCo
Yes just change the air spring shaft, have my current 2014 solo airs at 110mm and a team riders just had another set at 100mm both 29ers
Posted : 22/05/2014 2:11 pm
I'll give you a shout about that then, cheers.
Posted : 22/05/2014 2:37 pm
 LoCo
Posted : 22/05/2014 2:45 pm
