Reba 2010 - oil lea...
[Closed] Reba 2010 - oil leaking from rebound adjuster
[#3423817]
Noticed it at Afan last weekend; assumed it would be the crush washer, so did a lowers service today & replaced the CWs both sides. Oil is still leaking from the rebound adjuster.
There's a few posts online that indicate it could be a problem with the rebound damper seal. The fork is still in warranty; would it be covered? Or is it an easy/cheap job to do yourself?
Posted : 03/12/2011 10:29 pm
As said, probably the rebound cartridge seal leaking oil into the lowers. Should be covered under warranty.
Posted : 03/12/2011 11:10 pm
Common problem, has happened to Rebas and Revs here. You can replace the umbrella seal with an o-ring pretty easily, up to you about warranty, probably worth a pop.
http://www.basquemtb.com/repair-leaking-pike-motion-control/
Posted : 04/12/2011 12:22 am
Merlin have said that seals aren't covered under warranty & would cost c£100 to get fixed (including full service).
Surely it can't be that difficult to do myself. Any idea which seal kit I'll need?
Posted : 05/12/2011 12:25 pm
Normally just an o-ring on the rebound damper shaft, so not expensive, but the fork will need a full stripdown to get to it, and fresh oil for the rebuild. Try giving Locotuning a call for seals, I think he's sourced individual seals.
Posted : 05/12/2011 8:20 pm
