Rear sus play- bush...
[Closed] Rear sus play- bushing/bearing wear?
 TomB
[#6664305]
Hi all. When I lift the rear of my full sus bike by the seat there is a little play/clunk before the rear wheel lifts, which didn't used to happen.I think this is a common wear and tear issue and something needs replacing, but can't find the culprit by feel. Where should I be looking/what's it likely to be?
Posted : 26/11/2014 9:25 pm
Shock eyelet bush, probably.
Posted : 26/11/2014 9:28 pm
Shock bush/DU (reducer at eyelet).£15-20 per end.Measure the width (at linkage) and size of hole eg 22m x M8.
 TomB
Thanks guys, I think I've heard about these before, they are designed to wear to avoid wearing the shock eyelet itself, IIRC.
Posted : 26/11/2014 9:31 pm
Hopefully just the bush (pennies from local bearing shop) but often the fitting kit has worn in which case a 'strong bush' (got mine from TFtuned) is a worthwhile upgrade. A bush tool makes it a breeze, got mine from Kaesae of this parish, works a treat.
The bush joining the shock to the linkage is the one that wears fastest, and make sure to assemble bushes dry not lubed.
Posted : 26/11/2014 9:35 pm
[url= http://www.tftuned.com/tech-help/71-mount-kits-and-bushings-for-rear-shocks-a-guide ]What bike? Replace with one of these kits for better, longer bearing life.[/url]
Posted : 26/11/2014 10:13 pm
