3 speed internal gear hubs have been availible for over a hundred years. If you really dont want to shift it using a cable then i can hook one up to a servo if you want, yours for only £399.99
Yes, I am aware of Sturmey Archer. You may have missed my lightweight comments as a Sturmey Archer disc 3 speed for example weighs 1400g. So if you can make ether following I will buy one
Disc
under 500g
130mm OLN
Uses 15t cog for direct drive
Wireless changing via button that replaces brake lever bolt
When will it be ready?
Surely by putting a mech on its just a geared bike, regardless of the number of gears.
Part of what draws me to SS is the simplicity of it. And not having a rear mech to damage/twist/snap.
I'm not sold.
130oln? Road bike then?
And "rear speeding" had been around since the dawn of time. It's called "cheap shit bikes with 3/4/5 speed freewheels and gears that don't work very well."
Sorry, 135 not 130. Hoping that doesn't effect production time.
No idea. You'd have to check with someone who could make a business case stack up. Boris Johnson might be able to make something out of it.
The nice things about single speeding are the mechanical simplicity (no dangly bits, wires, levers) but also the fact that it forces you to push a bit harder all the time - either you're grovelling up a hill with your heart about to explode, or you're spinning like a loon to stay on someone's wheel, with your heart about to explode.
The only bad bit about SS is you inevitably end up going slower overall (at least I do), or just walking, which is annoying.
To me, this isn't in any way comparable.
It was directed back at twisty not you, twisty was the one offering to make a wireless changing lightweight 3 speed hub. The price was already set so he must have done his maths.
Yeah your weight requirement would be a problem. The sram i3 disk for example is 1.2kg, a lightweight freehub hub is 300g. Getting a gearhub below 500g would be very challenging it might need ceramic spur gears and stuff.
"[i]Have you ever tried to put together a bike using mismatched crap and a bit of skill rather than just breaking out the credit card?[/i]"
Yes. And judging by your posts, probably since before you were born.
About ten years or so.
And in that time I learnt - pretty quickly - that mismatched crap is just that.
So as far as I can tell, all you're doing is building bikes with gearing that's inappropriate to their use. I still don't get what's badass about it. You can slog your guts out grinding up a hill at 10rpm on any bike - just ride in the wrong gear. You don't need to build a special bike to do that. Put a 11-23 cassette on and stay in the big ring.
Totally don't get it.
Oh wait. It's school holidays, isn't it ?
To be fair, you could argue that the whole 1xn (for n>=9) with silly big sprockets is just bodging together something that's almost as good as a properly done 2x10 setup.
I think my 1x10 gears definitely make me badass. At least in my head.
Mr Jumper (is that of the wooley or dirt type). I'm just advocating an aspect of cycling that I have enjoyed. I like that it has an element of gear minimalism so it forces one to push ones body a bit. I get satisfaction from riding stuff that would otherwise be going in the bin (reduce, reuse, and cycle and all that).
If it is not your cup of tea then there is no need to get upset about it, I'm not trying to physically force it down your throat.
It probably does 🙂
Wondering if I should actually make some stickers now
'RearSpeeding - Reduce, Reuse & Cycle like a boss'
Don't think you will need many...
Yep, not easy, you may have over committed but I am sure you are up to the job. Let me know when you have made it and the £399 is yours.
And I don't want a sticker included thanks.
Being in a position where money is tight means you sometimes need to be a bit more creative, but you probably shouldn't call it badass 😉
And don't forget the 99p, but obviously I am not doing this, a few other things higher up the priority list than designing and manufacturing a superlight internal gearhub. If it were just a case of wirelessing an SRAM hub and you were serious I might have actually done something but as soon as you mentioned 500g I withdrew.
To be fair I only called it [u]fairly[/u] badass 😆
Nowadays it is not a case of not having money but I just like to know I've used stuff up 100% before I throw it away. Once I tried to give my wife a pendant that I made from some titanium XTR cogs and she was not impressed I had to buy her a silver one to get out of that one.
Not all that surprised, the ti sprockets are massive, that would look daft unless you were a die hard cyclist!
njee20 - Member
I was a die hard cyclist, but this didn't make it any more attractive to her. Maybe if she herself was a die hard cyclist then it would have worked!
That's what I meant. No one other then a fanatical cyclist would want to wear a used 34t sprocket around their neck. Slow typing.
Silver?
Pikey.
Oh so that is what you really meant, not my fault if you write like an 11yr old 😛
Silver?, Pikey.
In actuality I may have promised to get one but then never bought it, 😆
Oh teh ironing. Why did you reply after 2 months? 😕
Rear speeding! 😆 piss off.
Better late than never I guess.
obvious thread-bumping narcissism is obvious
