Rear shock - is fox...
[Closed] Rear shock - is fox ctd still rubbish
[#6654169]
Ok, looking for a new shock, I don't mind buying a ccdb air cs however they are a tad pricey for what will effectively be my spare bike, so have fox sorted there damping out on the float rear shock. I want quite a firm rear end.
And I don't want bos because it doesn't match the front!
Posted : 23/11/2014 12:15 am
Anyone?
Posted : 23/11/2014 2:00 pm
I can't answer yes or no but why not talk to loco or similar and get it tuned from the off?
Posted : 23/11/2014 2:01 pm
It's always quiet on here at the weekend. Your best bet is to re-post in work time when everyone uses it when they should be working.
Posted : 23/11/2014 2:33 pm
Must admit I like the CTD shock on my 2014 bike. The three settings are just right for me and the damping is good + better then my old RP23.
Posted : 23/11/2014 2:39 pm
Get a DB inline? £40 cheaper than a ctd factory.
Posted : 23/11/2014 2:40 pm
Just found out the rebound adjuster on mine has lost it's 14 clicks and just turns between 11 oclock and 1 oclock, has anyone else had this fault.
I may end up looking into CCDB CS as everyone seems to rave about them.
Posted : 23/11/2014 3:05 pm
Mine did that it was fixed and something to do with the ball bearing inside. I hated the ctd till I had it tuned but I've got a single pivot and it could perform excellent on a different bike.
Posted : 23/11/2014 4:13 pm
Can't comment on standard tune but had my CTD push tuned at tf and it is very good indeed.
Posted : 23/11/2014 6:01 pm
Stock tune of my 2014 CTD shock on a Saracen Ariel is pretty good; infinety better than the DRCV rubbish on the Trek Remedy I had.
Posted : 23/11/2014 6:12 pm
Depends on how fat you are. My 2013 ctd was rubbish, was better after some volume spacers. I wont be buying another fox in a hurry.
Have a ccdb now.
Posted : 23/11/2014 6:46 pm
