Rear shock air loss
[Closed] Rear shock air loss
[#2213308]
How much should / could a shock lose after pumping up?
If its losing air is that normal or a sign of service required?
Posted : 22/11/2010 1:32 pm
It looks like it loses 10-15psi on removal of the pump but it's actually re-fitting the pump that does it.
It shouldn't leak at all.
Posted : 22/11/2010 1:37 pm
Ahhhh...that explains it, pumped it up a week or two ago to around 160psi but i just put pump on to check a few mins ago and it was just below 150psi. Was just a tad concerned.
Posted : 22/11/2010 1:41 pm
As per Al, otherwise use you sag measurement to check if your loosing pressure, or take it off and stick it in a bucket of water.
Posted : 22/11/2010 2:51 pm
