Rear Shimano 4 pot ...
Rear Shimano 4 pot brakes microleak?
[#12948401]
Struggling here. Never quite been A1. New rotors and pads - works for a couple of rides. Thoroughly clean rotor, Wet n dry and car disc cleaner with new pads and same result, works for a ride or two.
Leaving the bike for four weeks seems to be the killer issue. Any suggestions? I would rather sort out the issue due to brake change requiring a motor to be dropped out. Which may well be the answer with a change to Magura MT5 pro. Been very impressed by MT7's.
Posted : 31/08/2023 1:41 pm
I had this with some SLX 4-pots on a Pivot Firebird I tested recently (review here). I tried multiple pads, cleaning the rotors and bleeding many times but to no avail. I’d suggest taking it up with Shimano’s warranty dept, or just sacking it off and getting a different brake from another manufacturer. Can recommend Hayes Dominion A4
Posted : 31/08/2023 3:02 pm
I had the same. I changed the caliper and it stopped doing it. Either warranty or just suck the cost up of a new caliper. Deore calipers aren't too much and are just as powerful, can just cut the banjo off the hose and connect with an olive and barb. You get a set of resin pads with the caliper which makes the price feel a little more worth it.
Posted : 31/08/2023 4:03 pm
Gotbike, now why had I not thought of that? Gone for SLX due to same Bango fitting.
Posted : 31/08/2023 7:24 pm
One very happy bunny here, SLX fitted and back to one finger stopping on a dime. Bleed  and bedded in.
Will try a longer ride tomorrow. It was great that the SLX had exactly the same hardware banjo fitting so a very easy swop for not a lot considering the time I have put up (months) with unreliable rear brake.
Posted : 03/09/2023 7:15 pm
Easy enough fix (not for me, can’t sort brakes to save my life!) but it’s frustrating that these issues continually crop up with shimano brakes.
Posted : 03/09/2023 9:12 pm
