Rear mech - spare p...
[Closed] Rear mech - spare part
[#8249267]
Does anyone know what the part circled below is called, and if they're available as spares? Bought a secondhand mech recently and it's not got this bit which is fairly fundamental.
Cheers,
Posted : 31/12/2016 12:09 pm
something like this. They also just do the bolt if that's all you need.
https://www.sjscycles.co.uk/gear-spares/shimano-deore-xt-rdm8000-bracket-axle-unit-normal-y5rt98010/
I'd be contacting the seller though!
Posted : 31/12/2016 12:23 pm
Thanks. Hopefully seller still has it somewhere, that's nearly as much as the mech cost.
Posted : 31/12/2016 12:25 pm
Someone on here is likely to have (several) knackered mechs where that part is OK.
Posted : 31/12/2016 12:27 pm
It may not have been sold with that part. The "Direct Mount" standard does away with it as that bit is effectively built into the mech hanger.
It's the bit you remove if you have a direct mount mech. Your LBS might have some knocking around.
Posted : 31/12/2016 1:25 pm
