XT m8000 1x
As above sticks in first, anyone else had this and sorted it? Grease clutch??
Indexing is perfect, i've spray lubed the inner at the mech clamp but still does it.
new cable? might have a kink in it.
Is the cassette/chain worn? Unlikely but the chain might be be jamming on the sprocket if bot hare worn badly and can't release off it.
Both new(ish) on a brand new bike this Feb. Could try new cable, cheers.
No one else had same then?
B screw?
Might need winding in if it's too close to the cassette.
B screw would be my guess too. My xtr B screw seems to need a couple of turns every now and then
Change the jockey wheels
Take the chain off and see if the mech still sticks.
If it doesn't you've ruled out the mech itself.
B tension screw would be the next thing to try
shifter has been bumped and is pressing against the brake lever - took me ages to work that one out!
B tension screw sounds likely.
B screw
APF
