Rear Mech Hanger Th...
[Closed] Rear Mech Hanger Thread Stripped
[#2254610]
I've stripped a thread on my rear mech hanger and the mech no longer fits. Does anyone know if it's possible to retap the thread? Is there a tool available that will do it?
Thanks
Andy
Posted : 05/12/2010 11:46 am
Get a new hanger and don't hang off your allen key this time.
If it's not a replaceable one then you can probably get a helicoil and don't hang off your allen key this time.
Posted : 05/12/2010 11:47 am
If the thread has stripped simply running a tap thru it won't really help as there is nothing left to create a thread.
If the mech hanger is not replaceable then an engineering shop / frame builders will be able to make an insert to fit to recreate the thread or build it up wilth weld and retap the thread
I dont know if a helicoil is available in that size but if so that is the best option
Posted : 05/12/2010 11:50 am
 Soup
Failing that, some really cheap mechs have a shim that bolts through from the other side - bit likethe rear part of a chainring bolt. Drill the knackered thread out slightly and it'll fit. Did this on a bike years ago that didn't have a replaceable hanger. Worked fine for years.
Posted : 05/12/2010 11:51 am
OK thanks for the tips. It is replaceable but I can't find anywhere that sells them.
Andy
Posted : 05/12/2010 12:05 pm
What frame is it? Your LBS should be able to order one in for you
Posted : 05/12/2010 12:06 pm
try this place [url= http://derailleurhanger.com ]clicky[/url]
bought my gt avalanche hangers from there and theyre great
Posted : 05/12/2010 12:09 pm
Thanks float. I'll drop them a mail.
Posted : 05/12/2010 12:17 pm
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=144&Name=Frame+Savers+and+Fixing+for+Dropout/Hangers ]BETD Frame savers. £8[/url]
i used these on my old super 8 worked perfectly.
hope that helps
Posted : 05/12/2010 12:29 pm
OOO, thanks for the BETD website link. They sell a replacement hanger that looks just like mine. I'll buy the hanger and a frame saver just in case it doesn't fit.
Thanks for all the help.
Andy
Posted : 05/12/2010 1:00 pm
