Rear maxle 12x135
[Closed] Rear maxle 12x135
[#4428397]
Having promised myself never to own s fs, one came up I fell in love and its rear end is now driving me bonkers.
I have spin dr pro's on sas rims, by using the halo 12mm conversion axle I have got the maxle to fit.
Problem being that there is a tiny <1mm bit of play. If I tighten the maxle anymore the freehub locks, I back it off to the point where it's turning again and the play is back.
If it makes a difference it's a 2010 Trail Attack.
Help!
Posted : 04/10/2012 5:05 pm
Something wrong with the freehub. Don't know that particular hub but hard to see it can be anything else. Did you do the conversion to 12mm yourself?
Posted : 04/10/2012 6:07 pm
Yeah, converted myself, was easy to do, it's stopping me riding!
The freehub is a silly idea as with the halo 12mm axle it's held onto the hub by the maxle clamp.
Posted : 04/10/2012 10:50 pm
Not stripped one of their hubs, but suspect that you may have a spacer hiding somewhere in your workshop, that should be between the hub and freehub body.
Posted : 04/10/2012 10:53 pm
+1 Coatesy, look around for a spacer that looks like a du shock bush but obviously a larger diameter, it will be on the floor somewhere!!
Posted : 05/10/2012 1:12 am
As with above, sounds like something's missing. I have an 09 Attack Trail and the Maxle winds all the way round before closing the lever.
Great frames, they chew up all sorts with a fairly casual shrug.
Posted : 05/10/2012 7:09 am
I'd guess spacer 2.
Won't be the maxle, I do mine up quite tight and it spins free, any time iv a wee but of play its new bearing time
Posted : 05/10/2012 7:40 am
cheers people, I am fairly confident nothing extra fell out but it would seem logical that this is what it is.
Will have a look.
Posted : 05/10/2012 7:43 am
have you actually put a different freehub on it? If so the spacer could well still be inside the old freehub body. Give it a tap and see if it falls out of the back. Embarrassingly this has happened to me :/
Posted : 05/10/2012 8:34 am
Its the same freehub going back on, the only thing that was changed is the axle, from a qr to a 12mm.
The old gr axle used to hold everything in place however now the maxle holds everything in place.
3 days I've been working on this now! will go fettle some more after some coffee.
Posted : 05/10/2012 8:44 am
So you know this spacer.....
I've spent 4 days looking at the spacer from the old qr axle. Turns out if I pop it into my maxle it gets rid of the play, you can achieve maximum tightness with no jammed hub. Imagine that.
Do I feel I pillock? Yes.
Have I learnt lots? Yes
Do I now have a new phat ride to go and abuse? HE'LL YES!
Posted : 06/10/2012 5:27 pm
Lol good work
Posted : 08/10/2012 2:06 pm
Hi pik n mix. Where did you get your halo Spin Doctor Pro 12mm Axle Conversion from?
I'm having trouble finding them.
Thanks
Posted : 08/11/2012 10:54 am
