Rear Hope Pro II co...
[Closed] Rear Hope Pro II conversion - Help
[#6341530]
Hi guys
Hope to have a new frame shortly however, the rear of the new bike is 12x142 so I'll need to convert my Hope Pro II Evo hub from QRx135.
Have got myself into a bit of a muddle if I need a new axle or just the caps.
Will some kid soul hold my hand for a moment and tell me what I need?
Posted : 15/07/2014 1:46 pm
If its the Evo version, just the end caps.
If its not, you need the axle too.
(I think)
Posted : 15/07/2014 1:47 pm
[url= http://cdn.hopetechnology.netdna-cdn.com/wp-content/uploads/2014/05/HUB-CONVERSION-KITS.pdf ]all part number here.[/url]
Posted : 15/07/2014 1:53 pm
Just the caps
Posted : 15/07/2014 1:54 pm
Definitely evo, brilliant! That saves me some faff, cheers me dears.
Is the conversion same as the fronts then, just pull off old QR caps and insert new caps?
Posted : 15/07/2014 1:56 pm
Yes, in a "you may have to stick it in a vice and use a bit of force to get the old ones out" sort of way.
Oh, and if your freehub comes away with it all at the same time, there are a couple of threads on here about making sure you seat the plastic seal properly.....
Posted : 15/07/2014 1:58 pm
That's all there is to it.. though, I needed to remove the cassette as the adapter wouldn't fit past the lock ring.
Splendid, 10 internet points to everyone.
Posted : 15/07/2014 2:01 pm
