rear coil advice
[Closed] rear coil advice
[#2713391]
i just broke my RP2 air shock and want to replace it with a cheap spring coil.
The air can is 200mm - 57mm stroke length, and chain reaction are selling Manitou Metel RP Coil Shock 2008 that are 216mm - 63mm Stroke, can i fit this to a specialized pitch pro without causing problems?
any advice is appreciated.
cheers
Derm
Posted : 03/05/2011 6:25 pm
Possibly, but it would steepen the angles and raise the BB quite a bit if it does fit without hitting anything.
Posted : 03/05/2011 6:30 pm
Out of curiosity how you broke your rp2?
Posted : 03/05/2011 7:54 pm
 sv
There was a cheap 200x57 coil in the classifieds earlier not sure if it sold or not.
Posted : 03/05/2011 8:06 pm
