rear cassette quest...
[Closed] rear cassette question
[#2813327]
I currently have an 8spd 12-26t cassette on my old winter/commuting/touring road bike. I'd like to replace it with a new 11-32t cassette (also 8spd). I guess I need a longer chain, but I need a new one anyway. I'm just worried whether the new cassette will work with my current derailleur? Any other potential problems??
Posted : 02/06/2011 3:34 pm
Worn chainrings?
Posted : 02/06/2011 3:35 pm
...and so slippage with new chain, is that what you're getting at?
Posted : 02/06/2011 3:37 pm
Can you look at the code on the mech to see if it is a medium/long cage (which I am sure it is) if its gs model it should be fine? Presuming its shimano ?
Posted : 02/06/2011 3:39 pm
mech is a tiagra and the cage is about twice as long as on my other 'sunday best' road bike, so I'm guessing its at least a medium if not a long cage.
I haven't mentioned yet that its a triple up front ( 😳 oh, the shame!) but that shouldn't be an issue should it? Middle chainring looks like it needs replacing, small ring looks as good as new, honest.
Posted : 02/06/2011 3:45 pm
length of cage is often independent of cassette capacity.
rear mechs are spec'd by (exclduing pull ratio and speeds):
* What the maximum sprocket size they have handle; and
* How much slack chain they can deal with (capacity in teeth - difference between big ring and little plus difference in teeth between little sprocket and big sprocket added to the chainring difference.) - longer the cage bigger the capacity to deal with more chain slack.
You might find an older 8 speed mech might not be able to deal with the 32, but fit it and see - you will have to play with the 'B' Adjust screw to get the correct clearance from mech top jockey wheel and 32 sprocket..
worth trying before you buy a new mech - nowt to lose by seeing
Posted : 02/06/2011 3:47 pm
techdocs for 9 speed tigra says max 27t sprocket size for med and long cage
makes sense as Tiagra is road groupo
Posted : 02/06/2011 3:56 pm
cheers rootes, that techdocs is dead handy.
Shame about max 27t though...
Posted : 02/06/2011 5:20 pm
Try it and see. The worst that'll happen is the mech sits on the bigger sprockets and it won't change very happily. In which case new mech time!
Posted : 02/06/2011 5:23 pm
Might chance the 11-30t then...
Another numpty question: there don't seem to be many 8spd mechs about, I could just use a 9spd and adjust the limits to give me just 8 gears, yes? That's if I end up needing a new mech.
Posted : 02/06/2011 5:28 pm
 Solo
[i]rear cassette question[/i]
I've a genuine Q.
Why do we call it a [b]rear[/b] cassette ?.
Its not as if we have front cassettes, to the best of my knowledge anyway.
Posted : 02/06/2011 6:31 pm
I'm running an an 11-28 cassette with a tiagra rear on my road bike with no issues...(actually it's a 12/28 as I did a futz between an 11-28 and a 12-25 cassette and swapped around some of the smaller sprockets)
Posted : 02/06/2011 6:35 pm
