Rear brake adaptor ...
[Closed] Rear brake adaptor help.
[#9749012]
Hi guys,
I’m swapping out the Guides on my Capra for some Zee brakes. The rear has as adaptor for 189mm to 203mm, however the new zee calipers are a different shape and doesn’t fit within the ‘bridge’ of the adaptor. Anyone know what adaptor I should be looking at? I need a post to post for a 203 rotor I think?
Thanks.
Posted : 02/01/2018 10:53 pm
Not sure if this much help as I know nothing about SRAM brakes.
Just moved a 180mm XT rotor and its adapter to the back of my T130 and put a new 203 XT rotor on the front with a new Shimano 203 adapter. Just get that adapter and you should be fine...I think!
This is what I got for the front.
http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747
Posted : 02/01/2018 11:30 pm
